Data lose after assign task
Avatar
Former Community Member
I have a xdp form and once user filled in details and submit it through workspace, it will flow to another user for approval. But all the form data is lose when the second user viewing the form.
Any idea what's wrong with the process.
Ivor
Avatar
Level 10
On the render service for the xfaForm variable, make sure the data parameter is set to Task->Form Data.
Jasmin
Avatar
Level 9
I suspect the problem is that you need to set the same xfaForm variable as both the input and the ouput of the User>assignTask step.
If you don't specify the output variable, what the user types doesn't get saved.
howard
http://www.avoka.com
