Learn about Edge Delivery Services in upcoming GEM session
XPath and XML nodes
Avatar
Former Community Member
Hello
I've a simple problem but can't figure out the solution in ES Workbench (Process Designer). My process uses a xml variable called xmlvar that looks like:
form 1
form 2
form 3
For example: I want to get the name of the second anyform element. My index is stored in a counter variable called posCount (type int) and the value is 1. I've tried the XPath selection:
/process_data/xmlvar/data/formList/anyform[/process_data/posCount]/name
That doesn't work. I'm always getting the first value ("form 1").
Anybody know why?
Nico
Avatar
Level 10
Nico,
I have copy/pasted your XML into a file and created a process that reads the file from the file system, put the content into an XML variable and then use /process_data/xmlvar/data/formList/anyform[2]/name to put the name in a string variable and I do get "form 2".
Are you sure you're xml variable is populated properly? Can you put a variable logger before your SetValue to double check the content of the variable?
Jasmin
Avatar
Strewth! This one was nasty... but finally I made it.
My approach had two failures:
* xml nodes, maps, list have not
0-based but
1-based indexes
* the statement has wrong syntax (but this
doens't result in an exception!!)
Ok, the correct statement look like this if your index is also a variable:
/process_data/xmlvar/data/formList/anyform[number(/process_data/posCount)]/name
That's it!
Nico
Avatar
Thanks Jasmin for your great support!
Unfortunately I could solve my problem (almost) in the same minute as you were testing my problem.... sorry.
Nico
Avatar
Level 9
Hi Nico
The xpath expression probably doesn't throw an exception because it's still a valid xpath expression, it just doesn't result in the data that you're expecting.
What would be very helpful in xpath expressions is a way of evaluating an xpath expression against the real data of a particular process instance. If you feel this would be useful, please log it as a feature request with Adobe.
Howard
http://www.avoka.com
