Get Email Address of Process Creator
Avatar
Former Community Member
I have a requirement to, at the end of my workflow process, render the form as a PDF document which will be mailed back to the process creator. Is there some way to obtain the creators email address within my process so that I can accomplish this?
Avatar
Level 10
You would probably need to query the database and get the email associated with the /process_data/@creator_id variable.
You can also use the API and build a custom component to do it.
Jasmin
Avatar
What table would I query? When you say "use the API and build a custom component" I'm not sure what you mean.
Avatar
that would not be necessary for you,as you can just query the DB and get the email
the sql query would be
select email from edcprincipalentity where id = '{$/process_data/@creatorID$}'
Avatar
It worked - I just had to add a JdbcService step, set the Datasource Name to the literal value java:\DefaultDS, and to define a data mapping to output the returned record to a string variable.
