Hi Kim,
Based on your workflow, I concur with the above post. Since you are pulling a form directly from the repository and it already contains usage rights, you should add the Form Bridge at design time of the form. The key is that this field needs to be added before usage rights are applied.
Please try the following:
- Open the Form in Designer and add the Form Bridge. It is an invisible field that can be added anywhere within the form.
- Re-save the form
- Re-apply the usage rights and upload the updated form to the repository.
If you were applying rights within your workflow, then yes you could do it using the service FormAugmenterService > Inject Form Bridge. But once again, the usage rights would need to be applied after the Form Bridge is added.
_Seth Reilly
