I want my customized workspace instance to have no timeout. I can see that from AdminUI User Management with core system seetings SessionTimeout variable can be changed to specific value for all system.
I my case two instance of workspace will work together, one for no session timeout and one for specific session timeout.
Is there a default value (such as -1 (not help)) for SessionTimeout which makes no timeout? And also can it be applied to only to specified deployed instance of Workspace?
Well I don't believe you can do it at a user level, as this is a system setting, which impacts the livecycle application such as the AdminUI, Workbench, and Workspace.
The actual value you would want to modify is called assertionValidityInMinutes the default value is 120. I would suggest just cranking up this value to something that would meet your needs.
There apparently isn't any maximum value like if you were to specify -1 to turn the context time off. If you really need this behavior it looks like your going to have to specify a large (int) value.
regarding the "assertionValidityInMinutes", the manual puts it under the "WorkBench" section... does it also affect WorkSpace and AdminUI? or there's some other parameters we need to change for WorkSpace/AdminUI?
