"Start Process" continuous spinning when loading a Flex Application
Avatar
Former Community Member
I am trying to kick off a process using a flex application. I have read over and followed the instructions in the Creating a Flex Application for LiveCycle Workspace ES PDF. I have successfully added the .swf to the workbench and referenced through an xfaForm, but when I load up workspace and try to start the process, I get a continuous spinning wheel like it is loading. However, nothing happens, it is basically stuck. The log file only gives me this:
"2008-02-13 15:00:29,701 INFO [STDOUT] [INFO ]Checkpoint complete.
2008-02-13 15:02:35,837 INFO [com.adobe.idp.scheduler.SchedulerServiceImpl] OneShot Trigger created ----------------------------------------
2008-02-13 15:02:36,541 INFO [STDOUT] Feb 13, 2008 3:02:36 PM com.adobe.workspace.tasks.TaskItemResult initialize
INFO: *** Content type from this document service is application/x-shockwave-flash ***
2008-02-13 15:02:39,869 INFO [STDOUT] Feb 13, 2008 3:02:39 PM com.adobe.idp.event.notification.NotificationManagerImpl retrieveEvent
INFO: retrieving active event for 4311
INFO: retrieved active event for 4311
2008-02-13 15:02:39,884 INFO [STDOUT] Feb 13, 2008 3:02:39 PM com.adobe.idp.event.notification.NotificationManagerImpl sendNotifications
INFO: Total subscriptions retrieved = 2 for event id4311
2008-02-13 15:02:39,884 INFO [STDOUT] Feb 13, 2008 3:02:39 PM com.adobe.idp.event.notification.NotificationManagerImpl createNotifications
INFO: Now creating notifications.
INFO: Created 2 notifications.
2008-02-13 15:02:39,884 INFO [STDOUT] Feb 13, 2008 3:02:39 PM com.adobe.idp.event.notification.NotificationManagerImpl retrieveEvent
2008-02-13 15:02:39,900 INFO [STDOUT] Feb 13, 2008 3:02:39 PM com.adobe.idp.event.notification.NotificationManagerImpl retrieveEvent
2008-02-13 15:02:39,931 INFO [STDOUT] Feb 13, 2008 3:02:39 PM com.adobe.idp.event.notification.NotificationManagerImpl deliverNotificationToService
INFO: Now delivering notification to service RemoteEvents
INFO: Now delivering notification to service operation onEvent
INFO: Now delivering notification to service operation parameters {eventType=TaskCreated}
INFO: Now delivering notification to service OrchestrationEventHandler
INFO: Now delivering notification to service operation parameters {eventTemplateId=STRT_ER1172599333679, serviceName=Task Assignment, eventTemplateType=eventReceiveAsStartTemplate, eventTypeName=TaskCreated}
2008-02-13 15:02:39,947 INFO [STDOUT] Feb 13, 2008 3:02:39 PM com.adobe.idp.event.notification.NotificationManagerImpl deliverNotificationToService
INFO: Notifications delivered
2008-02-13 15:02:39,947 INFO [com.adobe.livecycle.remoteevents.client.RemoteEventClient] message received type: event
2008-02-13 15:02:39,947 INFO [com.adobe.livecycle.remoteevents.client.RemoteEventClient] message received part 1: {data=[B@42769, event=TaskCreated}
2008-
Avatar
Sorry the message cut off, but basically there are no errors in the log file at all...
-Jordan
Avatar
Don't use an xfaForm variable as this is meant for xfa-based pdfs and FormGuides. Use a variable of type 'Form'.
Avatar
Thank you very much for the quick response
Still same problem though...
FYI
I have tried to mimic the settings from the
SimpleMortgageLoan-Flex for xfaForm, Form and I have tried the default settings for both xfaForm and Form...
Avatar
Level 3
I agree only use a Form Variable. Please also make sure that:
a) You compile your Flex Form using the workspace-runtime.swc located in the ..ES_SDK\misc\Process_Management\Workspace folder
b) Your Flex Form properly defines for example <lc:FormConnector id="connector"
Avatar
I had a similar issue that was fixed using the steps below,
1. Use a Form Variable
2. Ensure you compile your flex application using the same version of SDK as Workspace, which is 3.0.1
