BigFeetBigShoes wrote:
> All,
> Im trying to convert an Epoch number to a Date format.
The number is the
> total milliseconds from Jan 1, 1970 to today and is in
GMT. We are physically
> located in Central Time.
well if accuracy isn't such a big deal, divide the epoch
offset by 1000 to get
seconds then simply use dateadd (it might overflow w/ms).
otherwise might try
using java.util.Date & init it w/your epoch offset. cf
should be able to use
that datetime that it produces. i think the conversion will
also handle the
conversion to server timezone (tz). sorry this is from
memory, at home w/out
access to a server to test.
if you need other tz then have a look at:
http://www.sustainablegis.com/projects/tz/testTZCFC.cfm
but also read these, especially the tz hell entry:
http://www.sustainablegis.com/blog/cfg11n/index.cfm?mode=cat&catid=162AEDB4-20ED-7DEE-2A6CF1B79AC2E0...
