8 Replies Latest reply on Jul 3, 2007 11:55 AM by (Martz)
    Output Server Log File
      Hi Every One......
      There is a log File in the folder "...\Adobe\Central\Bin" Called "test_11.log" May be the name is not the same...
      Any way, I got in this log file the following:
      _____________________________________________________________________
      2004/12/12 16:50:29 jfmerge: [125]* Processing data file: 'C:\PaymentFiles\data\696UTF8_Updated.dat'.
      2004/12/12 16:50:29 jfmerge: [289]MDF file `C:\PaymentFiles\forms\YSDPAYCO_AR.mdf' opened.
      2004/12/12 16:50:29 jfmerge: [179]Possible variable substitution ignored. Variable 'TransCount' not found.
      2004/12/12 16:50:29 jfmerge: [108]Field 'DATA_START' not found on subform/page 'JFMAIN'.
      2004/12/12 16:50:29 jfmerge: [166]Data exceeds field 'Y_COMP_ADDR'. Spillage may be discarded.
      2004/12/12 16:50:29 jfmerge: [108]Field 'Y_YVPNA_KEY' not found on subform/page 'HEADER'.
      2004/12/12 16:50:29 jfmerge: [108]Field 'Y_521_TRAN_BLART' not found on subform/page 'ITEM_521'.
      2004/12/12 16:50:29 jfmerge: [108]Field 'Y_575_BLART' not found on subform/page 'ITEM_575'.
      2004/12/12 16:50:29 jfmerge: [108]Field 'DATA_END' not found on subform/page 'ITEM_575'.
      2004/12/12 16:50:29 jfmerge: [108]Field 'LDBOBJECT' not found on subform/page 'ITEM_575'.
      2004/12/12 16:50:29 jfmerge: [219]Incomplete last line within file 'C:\PaymentFiles\data\696UTF8_Updated.dat'.
      2004/12/12 16:50:29 jfmerge: [400]^define User:PageCountForTrans_1 1
      2004/12/12 16:50:29 jfmerge: [209]One surface was printed.
      _______________________________________________________________________
      Can some tells me or explains to me this kind of errors?
      Are these serious errors or not, because at the end, the surface is printed, and the form is working and gives what i want......
      If someone know any links or documents that explain these type of error or lof files, i be glad to see them,
      this is an urgent and i need to know as soon as possible.......
      Ahmed
        • 1. Re: Output Server Log File
          Level 1
          Well, ultimately, if you're getting the output you want, then the errors aren't that important however these messages are indicating conditions that might become trouble when you upgrade to a future version.
          Here's a run-down on the errors:
          Looks like the string @TransCount is in your data somewhere. @ is a special character in JfMerge that causes JfMerge to look for a variable substitution. If it fails to find something to substitute, it leaves the string alone. To get rid of the message change this to @at.TransCount .
          Indicates that the FIELD DATA_START was not found on the JFMAIN page, so it probably went off and found the page that it did exist on and used that. Nothing to worry about here, this is normal processing.
          The data provided was too long for this field. You may have lost data. You should probably double check the length of the incoming data against the length of the field in Designer.
          More normal processing.
          There was no line end (CR/LF on Windows, LF on Unix) on the last line. While not an error, this message is produced to warn the user that the data may be incomplete. Add a line end to the last line in the file to remove this error.
          Looks like a trace message. You probably have a ^trace command in your preamble somewhere.
          I hope this helps.
          Rob McDougall
          Indigo Pacific
          • 2. Re: Output Server Log File
            Level 1
            Thanks Rob, that was helpful. very nice explaination.........
            Once again Thanks......
            • 3. Re: Output Server Log File
              help from convert file to pdf
              • 4. Re: Output Server Log File
                Level 1
                What is specifically your problem???
                • 5. Re: Output Server Log File
                  Level 1
                  A perfectly valid question but why pose it 6 months after the original.
                  • 6. Re: Output Server Log File
                    Level 1
                    I just have seen it. It is better now than never...Maybe another person has the same doubt recently...don't you think???
                    Regards.
                    • 7. Re: Output Server Log File
                      Level 1
                      As I stated, your question was valid but IMHO following up after 6 months on a questionable statement that was originally made 2
                      b years
                      after the original question & answer was made just isn't worth it.
                      • 8. Re: Output Server Log File
                        Level 1
                        Perhaps my answer was outlined in the incorrect way. It had been better to have asked: Which your problem/doubt was, and how did you solved it?
                        Anyway, my humble intention was to help in some way, as well as to learn. Maybe not exactly to that person who originally had the problem/doubt, but to help another one who read the post with the same trouble. Although very late. I accept it...
                        We should leave this issue because it is out of the original post (started 2 years ago...XD XD)
                        Greetings!
