Learn about Edge Delivery Services in upcoming GEM session
Java and AS Value Objects problem
Avatar
Former Community Member
Hello,
I have an AS VO and corresponding Java VO, which I am using
for an LCDS application using AbstractAssembler (my application is
identical in structure to the employee/company CRM example in LCDS
examples application)
The problem I am having is within my DAO. Much like
EmployeeDAO.java, I am instantiating a new VO and then calling its
setter methods with arguments as the results of a ResultSet,
appending the VO's to a list, and then passing this back to the
Assembler.
When I run the application however, the only values that get
set are those of type String. I can see within the terminal
that these are set. The other local VO variables are of type
BigDecimal (Java) / Number (AS) and these never get instantiated.
Is this a problem with discrepancy between the AS VO and Java
VO? or is this an issue with my data-management-config.xml
defninition?
Any extra info can be provided
