Show 4 replies
1. Re: Web Flash Gallery Flicker between photos
Wolf Eilers Sep 21, 2008 12:08 PM (in response to Matthew A Kraus)Ensure that you have previews built for all images in your gallery. -
2. Re: Web Flash Gallery Flicker between photos
Matthew A Kraus Sep 21, 2008 12:48 PM (in response to Matthew A Kraus)Thanks for the reply. I already do have previews for these images. Unfortunately, the problem remains. -
3. Re: Web Flash Gallery Flicker between photos
(Graham_Gott) Sep 22, 2008 3:04 AM (in response to Matthew A Kraus)I've had the same problem all through the lightroom versions.
Just tried Slideshow Pro and transitions are now smooth as silk. Maybe a refresh rate problem? -
4. Re: Web Flash Gallery Flicker between photos
crowleyVT Oct 5, 2010 7:29 AM (in response to (Graham_Gott))I'm getting the same thing. The transition has a little "pop" right at the end before moving on to the next slide but doesn't happen with all slides. All my images are on an external drive that is served wirelessly to my computer.
You can see an example at this address. http://vimeo.com/15554651
Not sure what Slideshow Pro is but will check it out.
