Hi Luke,
Captivate 3 is, in fact, much better at handling full-motion
capture than is version 1 or 2, but it doesn't sound to me like a
"version problem" in any case. Personally, I wouldn't worry about
the frame rate - leave it at the default - as changing it is
unlikely to help, and quite likely will add a confusion factor to
your trouble-shooting efforts.
I agree with your thinking that it acts like a resource
problem. To eliminate this, you might want to open MSCONFIG ...
(Start menu > Run > (type) MSCONFIG > click OK)
... and go to the "StartUp" tab, de-select all startup items
in the list, then reboot and try again. (Don't forget to reinstate
the startup items you actually want when you are done
trouble-shooting).
I've seen this same behavior - kind of - caused by a
difference in alignment of the mouse-pointer (Demo mode recording)
on the slide prior to the full-motion (FM), and the actual position
when the FM starts. I never have the problem described earlier, and
I never settle for "close enough". Here is how I handle any
"jerking" when the FM begins:
On the slide before the drag-and-drop operation actually
begins, I carefully move the cursor to the exact position that the
drag should start. At that point, I make sure the cursor doesn't
move while I take a manual capture of the cursor and background in
that position. Then I begin the FM capture ... being careful not to
move the cursor until
aftermy left-click forces the full-motion capture to begin.
This takes a little practice, but will eliminate the "jerk" that
many see when FM begins.
Hope this is helpful.
