login question
Nov 29, 2007 Nov 29, 2007
I have a login script that verifies against a database. The script verifies the user name and password.
I need to verify the user type and then depending on the user type send the user to one of two pages i.e. user type 1 would go to index.cfm and user type 2 would go to user.cfm.
Any help would be greatly appreciated. here is my code:
<cfquery name="qVerify" datasource="clients">
SELECT TblUser.User_id, TblUser.User_Password, TblUser.User_Type
FROM TblUser, TblUserType
WHERE user_id = '#username#' AND User_password = '#password#'
</cfquery>
<cfif Verify.Recordcount>
<cfset session.allowin = "True">
<cfset SESSION.UserID = qVerify.user_id />
<script>
alert("Welcome! You have been successfully logged in!");
self.location="Processors_Home.cfm";
</script>
<cfelse>
<script>
alert("Your credentials could not be verified, please try again!!");
self.location="Javascript:history.go(-1)";
</script>
</cfif>
Advanced techniques
362
> </cfquery>
not related to your direct question, but...
1) i would use a proper INNER JOIN in your query instead of the
Cartesian join you are using
2) i would suggest scoping your username and password variables and USE
CFQUERYPARAM!
> <script>
> </script>
OK, so in order to tell which type current user is, you need to either
store that info somewhere (like SESSION scope var) or query your db each
time you need that info (not an optimal option).
I suggest you also store User-Type in the session scope (add <cfset
SESSION.UserType = qVerify.User_Type> to the script block above) and on
your Processor_Home.cfm page you will need to have an cfif/cfelse block
to check the value of this var and cflocate to correct page.
> <cfelse>
> <script>
> </script>
> </cfif>
alternatively, you may want to look at the cf's LOGIN and LOGINUSER
tags. Using the login framework gives you access to such useful
functions as isUserInRole, getAuthUser, etc
hth
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
Nov 30, 2007 Nov 30, 2007
Also, use cflocation to redirect instead of javascript, as you never want to rely on JS for crucial parts of your app like logins. Best wishes
Participant ,
Dec 06, 2007 Dec 06, 2007
I have not tested this code, but you could try something like this:
Documentation
