Hi Peter,
Thank you so much for the response. Actually, after I posted
the question on Forum we had lost internet connection for some time
and I just went ahead and tried it by myself.
This is what I did – since we use MS Visual Source
Safe, my all files were in the working folder of VSS in my c drive.
I just clicked the Open tab/More Files in RoboHelp Starter and
located the RoboHelp HTML Project File. It opened without any
problem. Everything looks alright.
Is there anything specific I should be checking to make sure
if it is working fine in this version of RH. Because I did not
create this project, somebody else did and I have never used this
tool before this is the first time I will be using.
I found your site pretty helpful though and it did have some
information about Source Safe. I still have one question related to
Visual Source Safe that Is RoboHelp v6 linked to VSS automatically
and check the files out from it automatically whenever a project is
opened or we have to manually set the link between the RH6 &
VSS.
In RH x3 whenever I would open a project it would prompt a
message that in order to open this project the following files need
to be writable, would you like to make them writable, selecting
that option would checkout all the files from the VSS to make them
writable. However, in RH V6 I opened an existing project and it
opened without checking out the project files from VSS. Do you have
any idea what’s happening?
Ps: Do you recommend any book on RH 6 for starters or any
other recommendation?
Your help is always appreciated
