SOLVED
fill() returning empty ArrayCollection
Avatar
Level 1
I am new to FDS and don't know why the fill() method returns
nothing, even though the assembler is returning a list of 3
objects. I know the list is returning nothing because when I
display the length of the ArrayConnection, it's 0.
I turned on debug logs and see the 3 items returned. Do you
have any tips on how I can resolve this?
Is there somewhere in the config where I have to specify that
Java class A maps to ActionScript class B? I just deleted my
corresponding ActionScript class and still got the same logs. I
suspect that FDS does not know how to map the Java class to the
ActionScript class so it gives me an empty list and throws away the
results. Does that sound right? If there is some kind of automatic
mapping, I would have expected to see an error in the logs after I
deleted the ActionScript class.
Jamie
[Flex] 05/18/2007 12:19:31.443 [DEBUG]
[DataService.Transaction] Committed trans
action
[Flex] 05/18/2007 12:19:31.443 [DEBUG] [Message.Data.fill]
After invoke service:
data-service
reply: Flex Message (flex.data.messages.SequencedMessage)
sequenceId = 0
sequenceSize = 3
(no sequence proxies)
clientId = null
correlationId = null
destination = company
messageId = 7A2A0D8F-C32B-80BC-D593-4551B71320F1
timestamp = 1179515971443
timeToLive = 0
body =
Company(companyId=100, name=null, address=null, state=null,
zip=null indus
try=null),
Company(companyId=101, name=null, address=null, state=null,
zip=null indus
try=null),
Company(companyId=102, name=null, address=null, state=null,
zip=null indus
try=null)
1 Accepted Solution
Avatar
Correct answer by
Level 1
I found the answer to my own question. This was just a race
condition. You can't read the size of the ArrayCollection right
away. The list takes a while to populate.
1 Reply
Avatar
Correct answer by
Level 1
