Hi, trying to work out how to check wether Form.startDate and
Form.endDate fall in between other start or end dates in the
database... currently using
SELECT cmsPollsID
FROM cmsPolls
WHERE '#Trim(FORM.eventStartDate)#' BETWEEN
cmsPolls.liveStartDate and cmsPolls.liveEndDate
AND '#Trim(FORM.eventEndDate)#' BETWEEN
works when the start date is between dates but not the end
date.
I agree about the dates. Storing date values as strings is
bad news.
If you want to check whether
either the start or end date fall between another range, use
OR instead of AND. You may also want to check whether they span
another range.
