I'm not sure why limited the amount of data per element would
make a difference (aside from limiting the total xml document
size). I know there is a size limit on the amount of data you can
send via a GET request. You can try switching your AJAX call over
to a POST, if it is not already. Also, if the size of your response
is getting to be an issue, you could always switch from XML to
JSON.
