Hi Rick,
Let me describe what is happening a little more clearly. Here
is the basics so maybe you can reproduce it. I belive I did come up
with a fix for myself.
1) Add a background image to the slide that is merged not an
overlay image
- My image is a png file imported into the library and added
to every slide. It has a solid light blue background with a dark
blue strip on top and a brand from the client at the top left (very
basic)
2) Add a transparent text box caption
3) Add text that includes bullet points
Result: When you put a text caption with bullets over a slide
background that is an image(even solid color) you get a ghost that
oulines the text caption dimensions. If the text caption doesn't
have bullets, the ghost outline doesn't appear, but the text is
blurry. Obviously the text can be fixed by highlighting on
character in #C0C0C0.
My temporary fix: Because the ghost ouline seems to appear
when a text caption with bullets is on top of a background image, I
modifed my background image so that the light blue part (this is
the area when all the content will be) is actually transparent and
no longer a color. I then set color for all slides backgrounds to
be the light blue that was origninally in my image. This seems to
work, but there are some color fading issues that I need to explore
and work out more.
Thanks much and look forward to pushing the boundaries of
Captivate once I my head around it more.
P.S If I have a background image on each screen (branding and
consistent purposes), when I set up a simulation, do I have to
merge each screen shot into the background or can the screen shots
created by Captivate just overlay my background image.
Lisa
