Has anyone run into a situation like this? [RH X5.0.2]
Occasionally, a little box appears above every list item in a
topic file (I hope it shows up in the attached code). This never
seems to happen while editing the file, but apparently develops
during the Generate/Publish process (might it even be the residue
of a failed rltnnnn.htm Review temp file?)
Although this happens rarely, it's embarassing to have your
reviewers giggle at the results of this glitch. Fixing it is
relatively simple, but we'd certainly like to prevent it happening
at all.
It depends on what character code is behind that goofy little
square. It may be something that sourcecode can't render correctly,
but shows up in html output.
If you look at the source code in the output file, what do
you see?
When you paste it in here, it takes a form that html ignores.
Now this all assumes that you're not talking about that
little black square in front of each item. ;-)
By chance was any of this content copied or otherwise
imported from Word? I ask because I found a long time ago that if I
copied a bulleted list from Word and pasted into other
applications, I would end up with weird little squares that I had
to later remove. Personally, I figured they were an odd
interpretation of a Word tab character. But maybe that's just me.
That
is the source code, and the goofy little boxes appear in the
source WYSIWYG
and in the output.
There's no code behind them, just the boxes, which appear on
their own line above the list items and aligned left with them (not
with the disc bullet).
Removing them manually, one by one, seems to keep them at
bay; at least, until they appear in another topic weeks later.
We had this issue a while ago and I'm trying to remember the
solution.
I believe it happens if the last thing you do in a topic is
edit the true code. Therefore, before saving the topic, go back to
the WYSIWIG editor and put something in -- even a space and save
the topic.
hmmm....interesting. Puts me in mind of that other glitch,
where you lose your edits if you immediately double click another
file in either of the Topics lists.
Actually, I think that certain anti-virus products wreak
havoc with RH: ever since our IT folks switched to Kaspersky, we've
experienced nothing but trouble.
Oh well, at least these goofy boxes haven't prompted any loss
of content or format. Sigh...
