Hi Jim
In additon to the thread Colum mentioned, you should also
know that RoboHelp 6 has a feature that can dramatically reduce a
need for build tags. This feature is called a Variable. So where
you may have in the past wanted to personalize output by using
Company1Company2Company3 and on and on and on, you now insert just
a single variable that can be changed at the time you compile or
generate.
Download the trial and check it out!
Cheers... Rick
