We have RoboEngine 4.0 installed on both our test and
production servers. I'm able to successfully publish and view the
help content from the test server. However, when I try to view the
content from the production server, it displays the message:
"Congratulations The RoboEngine has been successfully created... To
get started, you need to publish a project...".
When I try to publish to the production server from RoboHelp
HTML, I get the following error:
Publishing has been cancelled.
Connection failed. Please check the connection and post
again.
Native Error:Cannot accept uploading file. Further processing
is stopped.
I have tried everything I can think of... I have copied the
C:\Inetpub and C:\Program Files\RoboEngine directories from test to
production. I reset the permissions according to the tech note:
http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=rb_e01.
I also created a new IIS web site and corresponding virtual
directories identical to the configuration on test, but I still get
the same error.
Furthermore, I have tried to manually publish the project per
instructions in tech note rb_e67313, but that didn't work either.
Please let me know if you have any suggestions.
Greg
