Overriding form variables
Apr 26, 2007 Apr 26, 2007
Is there any way to override a form variable that is being passed. Would it be done via cfif?
Ok, that's a bit vague, so I'll try to clarify (I'm a little tired so bear with me ). I have the user fill out a form adding a new part to their inventory. If there going to take some parts out of the new stock there putting in to the database, it would leave a net amount (Gross amount being what was originally going to be inserted). So, on the update page, would I put that cfif statement in saying
<cfif #FORM.resNet# NEQ "">
<cfset #FORM.sOnHand# EQ #FORM.resNet#>
</cfif>
resNet being the resultant total of the previous calculation and sOnHand being the previous amount (gross) that would have been inserted in the form if the resNet field would have been left blank.
I hope my point got across.
Thank you in advance!
Advanced techniques
383
What happened when you tried the code you are asking about? By the way, in that specific piece of code, you don't need octothorps.
Apr 27, 2007 Apr 27, 2007
Element RESNET is undefined in FORM.
Why don't I need octothorps?
DOH, I had the field disabled. But, even though it's now enabled, (I created a hidden field so that field can be kept disabled and edited the script to output the answer to the hidden field), and changed my query and put it in a if statement, I get a new error:
Data type mismatch in criteria expression
It says it occurs here:
<cfset net = FORM.Net>
<cfif Net NEQ 0>
<cfquery name="aAddItem" datasource="#application.dsn#">
INSERT INTO iParts (pType, pNumber,sOnHand, sNeeded)
VALUES ('#FORM.pType#', '#FORM.pNumber#','#Net#', '#FORM.sNeeded#')
</cfquery>
<cfelse>
VALUES ('#FORM.pType#', '#FORM.pNumber#','#FORM.sOnHand#', '#FORM.sNeeded#')
</cfquery>
</cfif>
Are all your datatypes char or varchar?
It's an access database, so...the sOnHand field is set to Number, if that's what you're asking
Then get rid of the quotes around that value.
Advocate ,
Apr 30, 2007 Apr 30, 2007
a couple of (hopefully helpful) notes about your syntax:
</cfif>
1) Dan's octothorp comment: If you are using a CF variable inside a <cfif> or <cfset> tag, you don't need to use the # symbol. CF will evaluate those values.
2) The second line should be: <cfset FORM.sOnHand = FORM.resNet> (notice the = sign)
Documentation
