ok so i seem to continually get an error when trying to make
my drop down box options have a value that would go into the sql
statement to decide which gallery to display. i am going to copy
and paste my code below and the error. please help me as much as
possible. also remember i am a newbie to coldfusion and the syntax
to it.
Page:GalleryTypeMenu.cfm
Code:
<cfset Gallery_type1="Profiles.type='model' and
'dancer'">
<cfset Gallery_type2="Profiles.type='model'">
<cfset Gallery_type3="Profiles.type='model'">
<html>
<head>
<title>Untitled Document</title>
<meta http-equiv="Content-Type" content="text/html;
charset=iso-8859-1">
</head>
<body>
<cfform method="post" name="Gallery" id="Gallery"
action="gallery.cfm">
<cfselect name="Gallery" id="Gallery"
title="Gallery_Options">
<option id="Gallery_type1" value='variable.Gallery_type1'
selected>All</option>
<option id="Gallery_type2"
value='variable.Gallery_type2'>Models</option>
<option id="Gallery_type3"
value='variable.Gallery_type3'>Dancers</option>
</cfselect>
<cfinput type="submit" name="Submit" value="Go">
</cfform>
</body>
</html>
Page: Gallery.cfm
Code:
profiles.type='dancer'">
<cfquery name="All_Profiles" datasource="All_Access"
dbtype="dynamic">
SELECT Profiles.Last_Name, Profiles.Type, Profiles.Picture,
Profiles.First_Name
FROM Profiles
WHERE <cfoutput>#form.Gallery#</cfoutput>
ORDER BY Profiles.Last_Name
</cfquery>
<html>
<head>
</head>
<body>
<p> </p>
<table border="0" cellpadding="1" cellspacing="1"
align="center">
<cfoutput query="Profiles">
<cfif profiles.currentrow mod 3 eq 1>
<tr>
</cfif>
<td>
<img src="Images/#Profiles.picture1#" width="200"
height="200"><br>
<center><strong>#profiles.First_Name#<br>
#profiles.Last_Name#</strong></center>
</td>
<cfif profiles.currentrow mod 3 eq 0>
</tr>
</cfif>
</cfoutput>
</table>
</body>
</html>
Error Message (when clicking submit button):
The web site you are accessing has experienced an unexpected
error.
Please contact the website administrator.
The following information is meant for the website developer
for debugging purposes.
Error Occurred While Processing Request
Error Executing Database Query.
No value given for one or more required parameters.
Resources:
Enable Robust Exception Information to provide greater detail
about the source of errors. In the Administrator, click Debugging
& Logging > Debugging Settings, and select the Robust
Exception Information option.
Check the ColdFusion documentation to verify that you are
using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1;
.NET CLR 1.1.4322; .NET CLR 2.0.50727)
Remote Address 127.0.0.1
Referrer
http://localhost:8500/cfide/all_access/TMP71jbrgu1if.cfm
Date/Time 20-Apr-07 11:20 PM
any help would greatly be appreciated.
