I'm ready to pull my hair out. I have just created a new view
in SQL Server 2000 using the query designer. However, I cannot get
the code to accept a case statement, which is supposed to replace
the IIF statement that I was using in Access. Here is the code in
the query designer:
SELECT dbo.company.CompanyName, SQRT((69.1 *
(dbo.zipcodes.Latitude - 32.716263)) * (69.1 *
+ (69.1 * (dbo.zipcodes.Longitude - - 117.11426) *
COS(32.716263 / 57.3)) * (69.1 * (dbo.zipcodes.Longitude - -
117.11426) * COS(32.716263 / 57.3)))
AS Distance
FROM dbo.company INNER JOIN
dbo.CompanyXSignType ON dbo.company.CompanyID =
dbo.CompanyXSignType.companyID INNER JOIN
dbo.zipcodes ON dbo.company.Zip = dbo.zipcodes.ZIPCode INNER
JOIN
dbo.radius ON dbo.company.radiusID = dbo.radius.radiusID
INNER JOIN
dbo.signTypes ON dbo.CompanyXSignType.signtypeID =
dbo.signTypes.SignTypeID
I am trying to add this code to the mix, but it will not
accept it:
TooFar = CASE WHEN[distance] > [radius].[radius] THEN 'no'
ELSE 'good' END
This is the error I get: The Query Designer does not support
the CASE SQL construct.
If I try to add it to the "column" area, it spits out the
code as a text string.
I am new to SQL Server 2000, so any help would be
appreciated. I found some articles on creating a function and using
the case statement, but I have no idea how to do that or then, how
to call it in my query...
