How to replace or clean logo in the bottom
Apr 23, 2007 Apr 23, 2007
I would like to replace or clean logo in the bottom, any suggestion is appreciated.
Presenter
1.0K
You should be able to accomplish this by modifying the vconfig.xml file.
Add this tag to the xml file:
<uireplace name="logo" value="resources/logo.swf"/>
Read more on this page: http://thewarp.org/blog/index.cfm/2007/3/15/BreezeAdobe-Presenter-XML-Options
Thank a lot. it does work.
Apr 24, 2007 Apr 24, 2007
Thanks from me as well.
As you point out in your blogs, the loading screen is a significant issue. If we can't customize it, Adobe should at least remove their name from it and make it totally generic.
Is there any way to remove the slide duration from the outline? It takes up a lot of room.
The quality of the audio I get from Presenter is not as good, for a given file size, as other powerpoint to flash converters. Have you noticed this? All in all, Presenter is very good.
Apr 25, 2007 Apr 25, 2007
First - kudos to the guy who wrote the blog entry, but it's not me ;)
I don't think you can remove the slide duration from the outline.
You can set the sound quality: Choose 'Adobe Presenter -> Preferences -> Quality'. Here you can change the output audio quality.
Guest
You *can* remove any portion of the interface you like via Actionscript - just write a simple Flash module with your code and import it into the first PPT slide before you use presenter. I usually tie to a totally fake "click here to get started" button our students seem to expect.
Pick what in the interface you want to hide, and set its object ._visible=false. For example:
_root.m_controlBar.m_scrubBar._visible = false;
May 01, 2007 May 01, 2007
asm0d,
Thank your information. I would like to know how to remove the "Adobe Presenter" when the loading screen. the loading screen is a significant issue. If we can't customize it, Adobe should at least remove their name from it and make it totally generic. I just want to hide "Adobe Presenter" , would you tell me the detail information about hiding it.
Help resources
