Hi again
When you say "network", are you indicating that you have
created a project (.CP file) that lives on the network, where you
later open Captivate and work on it while it is still on the
network? If so, you need to close Captivate, then copy the project
file to your C: drive and try again. That could be the issue.
The only limitation to the trial is the time you have to use
it. And the fact it automatically sets an expiration date for any
movie you create using the trial. Once you upgrade to the full
version, you will need to turn off the expiration date for the
projects you created using the trial version.
Cheers... Rick
