Sorry bawd, try this link
http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=65&catid=451&threadid=1167875
The topic has a few ideas/approaches.....
Personally this is the approach that I use. Not as fiddly as
it looks:
This is how I hide topics from the webhelp search tab. It is
a manual process, but we only run through the process/tweak before
major builds. Its not as daunting as it first seems. I think that
this may trick may have originated from the good RoboWizard but I
don't have the time to find the source of this trickery right now
(apologies if there is an element of plagiarism Rick).
How to exclude the pop up topic from the search:.
1. Generate the project.
2. Go to the webhelp/publishing folder. Copy the files (e.g.
popup_xyz.htm etc). that you wish to exclude form the search to a
nice safe location You'll need these files later.
3. Now set up a new conditional tag in your project (e.g.
not_in_search).
4. Apply this conditional tag to the topics you wish to
exclude form the search (e.g. popup_xyz.htm etc).
5. Delete the entire contents of the webhelp output folder.
6. Generate the project again (this time, make sure your
build expression excludes the topics that you have marked with the
conditional tag e.g not_in_search).
7. Once the generation process is complete. Copy the files
that you put in nice save location (e.g. popup_xyz.htm etc to the
webhelp output folder).
8. Run your help and the popups will not appear in the
search.
Note: This tweak needs to be run every time you want the
topics excluded, so you may just prefer to do it when you area
about to ship a version of your help system.
Kind Regards
Craig
