Read a RSS feed into my html page
Mar 20, 2007 Mar 20, 2007
Hi
Just need some advice.
I have a rssfeed that is in swedish so i get some specialcharacters in it like åäöÅÄÖ.
I use this code
<cfhttp url=" http://blogg.fotbolldirekt.com/xml_consult.php" method="GET" resolveurl="no" charset="utf-8" ></cfhttp>
<cfset fdblogg_xml=XMLParse(cfhttp.FileContent)>
to call for the rss feed.
then i use this code to output the result
<cfloop index="x" from="1" to="3">
<tr><td colspan="2"><a href="#fdblogg_xml.rss.item.link.xmlText#" class="NewsName">#fdblogg_xml.rss.item.title.xmlText#</a></td></tr>
<tr><td valign="top"><img src="#fdblogg_xml.rss.item.urlthumb.xmlText#" border="0"></td><td valign="top" class="Text">#Mid(fdblogg_xml.rss.item.description.xmlText,1,80)#...</td></tr>
</cfloop>
Can anyone give me a hint, need to figure out how to get the specialcharacters to show correct on the webpage.
Magnus
Advanced techniques
673
Try adding this: <cfprocessingdirective pageEncoding="utf-8"> to the template.
Hi again
And thanks but that didn't do the trick.
Any other suggestions?
Put the processing directive at the top of the page.
Use the <cfsavecontent tag to set the encoding.
Put encoding code into metatags in the <head> of the document.
And I usually put in the <cfencoding...> tags in for forms and urls just
in case.
Do all the above all the time when working with encoding. And don't
forget any other layers: databases, xml documents, ect. They must all
agree on and use a consistent character set to prevent unpleasant behavior.
Im sorry but i still cant make it work.
Here is my complete page in code...
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Test RSS-feed</title>
<cfhttp url=" http://blogg.fotbolldirekt.com/xml_consult.php" method="GET" resolveurl="no" charset="utf-8"></cfhttp>
</head>
<body>
<cfoutput>
<table width="185">
<tr><td colspan="2" bgcolor="66CCFF"><b>FDs Bloggtips</b></td></tr>
</cfloop>
</table>
</cfoutput>
</body>
</html>
If it works for someone else then i can guess i have some config to do on the server.
/Magnus
i just tested your code and it worked absolutely fine... all Swedish
chars showed properly...
what's the page encoding setting in the browser you are viewing your
page with? make sure it is Unicode (UTF-8), too.
(I.e. in Firefox go to menu View -> Character Encoding -> select Unicode)
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
Mar 21, 2007 Mar 21, 2007
The one thing I would add is a <cfcontent...> tag.
<cfcontent type="text/html; charset=utf-8" reset="yes">
<head>
Documentation
