1. Re: Lighting Effects Filter Lines
Ed Hannigan Jul 16, 2008 6:22 AM (in response to schlossd)Do they print? -
2. Re: Lighting Effects Filter Lines
(Phos±four_dots) Jul 16, 2008 6:59 AM (in response to schlossd)Do the lines change position when you zoom in and out? -
3. Re: Lighting Effects Filter Lines
(BrendaJ50) Dec 3, 2008 6:03 PM (in response to schlossd)I have the same problem. Any ideas on how to correct this? -
4. Re: Lighting Effects Filter Lines
dave milbut Dec 3, 2008 10:52 PM (in response to schlossd)> Chris Cox - 01:17pm Feb 7, 2003 Pacific (#7 of 15)
> If you zoom in and they go away, it's probably the video card.
> If you zoom in and out and they change, it's probably bad RAM.
> If the image looks fine, you save it, then reload it and it's corrupted - then it's probably the hard disk. -
6. Re: Lighting Effects Filter Lines
dec9 Jan 5, 2010 9:49 PM (in response to v.elechi)Try updating to XP SP3.
Looks like a driver problem.
7. Re: Lighting Effects Filter Lines
schlossd Mar 9, 2010 11:33 PM (in response to schlossd)Update: Never resolved this issue. I have since reinstalled and that did resolve it...uhhh guess I did resolve it...Case resolved!
8. Re: Lighting Effects Filter Lines
schlossd Apr 6, 2010 1:10 AM (in response to schlossd)Still working on this. I reinstalled CS3, made sure all the updates were there. And found that it only happens on the HP workstation we use for photos. The other PC's and MACs do not have this issue. I took the plugin for lighting effects off one of the other PC's and replaced it on the bad HP...no change. Here is what it looks like. It prints this way and I can clone over the lines. CPU??
9. Re: Lighting Effects Filter Lines
I_Am_Cdn Apr 7, 2010 10:36 AM (in response to schlossd)I am also having this same problem.
It started with my new computer I bought last year, and I never had the problem on any other system. The problem has followed me from 32bit XP to my current 64bit Windows 7.
I get the impression that it is likely a video card issue, but I haven't been able to figure out what with the video card may be causing the problem. I am currently using a nvidia 9600, but I am strongly considering buying a new video card just to fix this problem.
What video card are you using?
