Show 5 replies
1. Re: Info Pallete Bug? (CS3 and CS4)
Mylenium Nov 22, 2008 3:08 AM (in response to bpylant)I don't follow. The behavior is correct and logical. The "transparent background" does not register as valid content, so no blending operations are calculated for it which in turn means that the pixel values don't change from their original values. This is no different in other programs that employ such a scheme, e.g. After Effects - you see a grid or solid colored background, but it does not influence the calculations of the layers.
Mylenium -
2. Re: Info Pallete Bug? (CS3 and CS4)
bpylant Nov 24, 2008 6:39 AM (in response to bpylant)It's not a blending, it's an opacity, and the image will output at something less than 100% opacity. IMO that is what should be reported in the Info palette, since I am actually changing the opacity of the layer regardless of what it falls over. If I set a 50% tint to 50% opacity, that layer will output as 25% tint -- if that is over nothing then it will just be 25%; if it's over some other background then that will be added to the 25%.
If this is functioning as designed then I would say it's confusing at best and dangerous at worst -- if I'm checking ink values for an image to make sure they are within print range, the Info palette should give me accurate data as to how the image will output. -
3. Re: Info Pallete Bug? (CS3 and CS4)
klsteven-vBdprK Nov 24, 2008 9:58 AM (in response to bpylant)In CS4 you have the options to set the Info palette to "actual layer" or "all layers". The problem is, I can see no difference. The values are always the same. -
4. Re: Info Pallete Bug? (CS3 and CS4)
klsteven-vBdprK Nov 26, 2008 3:27 AM (in response to bpylant)Can anyone give me an example of what the difference between "actual layer" and "all layers" in the options of the eyedropper tool is?
(Sorry, I mixed up the eyedropper tool with the info palette in my previous post.)
I always get the same values (of course on multilayered files) no matter wether it`s set to "actual layer" or "all layers".
I`m on a german version, so I`m not sure how the correct translation of the commands is. -
5. Re: Info Pallete Bug? (CS3 and CS4)
klsteven-vBdprK Dec 2, 2008 2:12 AM (in response to bpylant)Anyone?
