RH6 crashes with <th> and conditional build tags
Guest
Mar 12, 2007 Mar 12, 2007
Hello together,
The attached code worked fine with RH X5, but leads to a crash with X6. To fix, you have to replace the <th> by <td>, but it is not too easy to find the topic within a project. The fix is quite easy, but it is hard to find in a big project.
This happens, when the conditional build tag is used.
Thanks and best regards,
Katrin Lusser
252
I just tested this and it does crash as you describe. However, the <th> tag is used to define a header row which the cell with that in is not. I then created an identical table and there was no sign of a <th> tag.
Has the content been edited in anything else or lifted from some other editor?
Guest
Hello Peter,
My wife created the topic with X3 or X5.
She just tried again with X6 and after several changes (set heading, insert, delete, etc.) she had the same constellation. Unfortunately, until now, she could not find out the exact way to reproduce. But it is definitely possible. We will post here, when we find out, how to do it.
Best regards,
Michael
TH is the tag for a table heading but do you need to define the heading row as such?
It is not the same as applying a Heading style to some text in the top row. If you just do that, you will not get the TH tag.
RoboHelp Documentation
Download Adobe RoboHelp
