Show 8 replies
1. Re: CS4 drag-resize brush option problem
wes1 Jan 6, 2009 10:49 AM (in response to John K. Shaw)John, some info please. Are you using the right mouse button plus Alt key? When changing the hardness, I have to hold the Shft key first and then the Alt key before I click and drag with the right mouse button. I am using Vista Ultimate 64 but that shouldn't make any difference. When some of these little irritants pop up, I usually restart PS and delete the preferences to see if anything changes. Just a suggestion.
Wes -
2. Re: CS4 drag-resize brush option problem
John Joslin Jan 6, 2009 10:52 AM (in response to John K. Shaw)Edit > Cursors > Brush Preview.
Don't bother with the preferences and give yourself un-necessary hassle! -
3. Re: CS4 drag-resize brush option problem
John K. Shaw Jan 6, 2009 11:00 AM (in response to John K. Shaw)Yes, I'm using the right mouse button, and yes I've reset the preferences, and yes the color set correctly in the Preferences. It all works just as it's supposed to...except I don't get the color overlay also. -
4. Re: CS4 drag-resize brush option problem
Anthony.Ralph Jan 6, 2009 11:09 AM (in response to John K. Shaw)Check in the cursor section of the preferences. What colour is set for 'brush preview'? The default is red, but it can be changed to any colour - I wonder if somehow yours has been set to something different?
Anthony. -
5. Re: CS4 drag-resize brush option problem
John K. Shaw Jan 6, 2009 11:21 AM (in response to John K. Shaw)No, the color is set as red. I even tried selecting other colors, in case of some weird conflict, but no luck. Like I said, it all works but no color overlay appears. -
6. Re: CS4 drag-resize brush option problem
Wolf Eilers Jan 6, 2009 8:48 PM (in response to John K. Shaw)>Like I said, it all works but no color overlay appears.
Is OpenGL Drawing enabled in your preferences? If it is then something in you GPU driver is preventing the overlay to appear. Update to the latest driver. -
7. Re: CS4 drag-resize brush option problem
John K. Shaw Jan 7, 2009 6:09 PM (in response to John K. Shaw)OpenGL is not enabled, and I have the latest driver. -
8. Re: CS4 drag-resize brush option problem
Wolf Eilers Jan 7, 2009 7:48 PM (in response to John K. Shaw)OpenGL
b must
be enabled for the colour brush overlay to show.
