Hi to all,
thanks for your answers! I am still absolutely perplex ... it seems that only I have this probleme .. !
I will check all the solutions you've suggested (the RAM and virus-stuff) and hope that something gonna work --
Thanks to all of you.
Nina
*my account seemed to be broken since they relaunched the forum but: I am nina1234567... so hope you gonna see this*
STILL same problem!!
Meanwhile I re-installed Photoshop and because of the missing positive result I then also re-installed my whole CS4-Package!!!
I don't get it! I never had this problem with CS3!! Since I installed CS4 this problem occures!!! *ARGH*
And I cannot understand why I should be zhe only one who has this problem!!! I really searched the whole internet - NO RESULTS!
If I want to batch some .png-files, i have no choce: I have to open them by hand and if after a while the problem shows up, I have to shut down PS and open it again and then the the manual opening goes on!
Any solutions?
Greetz,
Nina
P.S. My collegue has the same problem!!!!! And he heard it could be a bug.... well -- they didn't seem to have fixed it yet! argh!
Hello,
i too got the same problem too with the PNG. Every time i open 2-3 "Big" document and i want to open a PNG i got the parsing error message.
I'm running WinXp Pro 64 sp2 intel core 2 quad CPU q700 @ 2.66mhz, 8.00GB ram. NVIDIA Quadro FX 370.
All is brand new, ie.CS4 was like the first thing i installed. Its pretty weird and closing/reopening PS is not the best workflow around.
If anyone have an idea on how to solve this, i'm taker.
-" Every time i open 2-3 "Big" document and i want to open a PNG i got the parsing error message."-
I used to have this exact problem with CS3, but never 2ith CS4 or below CS3. (Win XP 32bit Quad Core CPU, Nvidia 9800, 4GB RAM)
However, i fixed it. My problem seemed to be the files location was in a deep directory and any png files i opened from there crashed photoshop. I simply moved the files and renamed aload of folders going down to the directory to make the path name shorter and it opened them fine. This solution worked, but i did see the probelm make a come-back after a few months that was not have been caused by the same thing.
We are facing the exact same problem here on 4 PCs with Adobe Photoshop CS4 Extended - support is not very helpful as they are only sending back standard makro answers.
Resetting preferences in Photoshop, reinstalling and a clean new installation did not help - the problem remains.
Anyone any idea on how to fix this? This is really a killer!
I'm having the same problem! It's making me CRAZY!
I keep getting 'cannot be parsed' message and my files are being saved to a file deep dark location. I've reset the preferences several times and it keeps coming back.
Help Please!
FYI: I did a factory reset on my laptop a few days ago, reinstalled Design Premium and now have this issue. Never had any problems before. Grrrr!
Kristin
Hi Nina,
Did you find anything to fix this problem? I am in
exactly the same position as you were with exactly the same problem. I've tried everything mentioned
in the forums but to no avail. The one thing I didn't try was replacing the .8bi. file because that was for CS2 and CS3 and I don't know whether things are the same in CS4.
I can't believe how many people have this problem or why Adobe don't come out with a solution. - Unless I'm missing something of course.
I'm operating in Windows Vista Home Premium and CS4 Extended and have heaps of ram etc. I can open the PNG files in my old elements and CS3 so it's a problem with the software not the individual files.
Cheers
Maggiestam
Hi Maggistam,
fortunately I dont't have this problem anymore...but not, because I found a good solution.. but because I got a new computer and I think with little different hardware or preferences... I don't really know why, but since then I can work the same way I had worked before all this crab appeared.
I am sorry, that I cannot help you all with a better answer... I just hope, that this problem will never appear again...
But I cannot be sure.
Maybe this problem appears only when there are certain factors coming together .. and we all are one part of a "funky abnormal crowd".
But ADOBE should find a way to solve this problem immediately!!!
Cheers,
Nina
Thanks so much for getting back to me Nina. It's all so very frustrating. It
is about time Adobe sorted it out as there are so many people having the
same problem. They have been totally unhelpful so far. I'm glad it's all
sorted out for you, though and I certainly hope it doesn't reoccur on your
new computer.
I'm waiting to hear back from Adobe so we'll see what happens there.
Cheers
Maggie
I have the same problem!! So Annoying!
My problem started after I did a factory reset on my laptop and reinstalled Design Premium. I can use all my Design Programs normally, except Ps. Isn't there anything that can be done to fix this? I didn't 'deactivate' Ps before I did the reset, could that be the problem? Don't know, it's a long shot, I'm sure.
My laptop will be replaced in a couple days...not because of this problem but because I'm upgrading. I would love to find a solution in case this happens again.
Nina - Do you mind me asking which computer/laptop you got?
Kristin
There was a fairly recent post here, on corrupt Photoshop files, and a repair utility, that I had bookmarked. HERE is that utility.
That would be my first place to look. I have not used it, nor have I needed to, but it came highly recommended from others.
Good luck,
Hunt
Adobe can't solve corrupt files.
They are corrupted by bad disks, bad RAM, or other applications (malware mostly) on your hard disk.
Photoshop simply reports problems reading the files when the files are corrupt.
Hi Chris,
I don't know if you got the problem right.
Photoshop just says the file is corrupt, but when I skip PS and then reopen it:
Surprise: now PS has no problem to open the file!!
So the file doesn't seem to be corrupt at all, because when it would, then it should stay corrupt 5 minutes later.
Cheers,
Nina
Nina,
I have had the same problem like yours. So I just open the file in Paint Shop Pro X2, save it as a copy and open the copy in Photoshop. Then everything is fine. Some have done the same using GIMP. Maybe it won't work on the really botch corrupt files.
Thank you. When you save it again what format do you use? PNG again or PSD?
or Jpeg?
Cheers
Maggie
