Show 4 replies
1. Re: Noise removal with PP CS3
(tlc51369) Dec 30, 2007 8:35 AM (in response to juskocf)The only option you have is using After Effects. It has a remove grain filter that works very well!! It is a render hog though! -
2. Re: Noise removal with PP CS3
juskocf Dec 30, 2007 8:56 AM (in response to juskocf)Hi, tlc51369, thank you very much for your reply.
But I don't know the workflow. Is it to open the clip in AE and remove the grain, then save the clip and open it in PP ? What is the best workflow with PP and AE as far as removing grain is concerned please ?
Best Regards -
3. Re: Noise removal with PP CS3
(tlc51369) Dec 30, 2007 8:22 PM (in response to juskocf)If you have Dynamic Link that would be the best workflow but if not you can copy and paste the clip from Premiere into After Effects and then remove the grain. Once removed you can render that file out and import back into Premiere. -
4. Re: Noise removal with PP CS3
juskocf Dec 31, 2007 6:10 PM (in response to juskocf)tlc51369, thank you very much for your help. I will give it a try.
Happy New Year to you and your family.
Best Regards
