VHS-look plugin
Jul 03, 2008 Jul 03, 2008
Hi guys, I'm looking for a plugin that can give a VHS tape effect. The look of being recorded over 20 times - a bit jittery, slightly distorted, color bleed, etc. I have seen it done, just don't know what was used.
81.7K
imagination and a little effort was most likely used instead of a plugin.
There are plenty of "tools" available for you to create this and it depends on what you see as a "VHS look"
FWIW - I have never seen a plugin called 'VHS LOOK'
Jul 04, 2008 Jul 04, 2008
Prizm4,
You seem to have a good start on what constitutes that "look."
I'd add: noise and higher contrast, especially in the colors. The often seen head alignment problem at the bottom of the frame would go a long way towards getting the "VHS look." Maybe capture from a VHS without perfect head alignment (like one could ever get them perfectly aligned?) and create a lower 1/16 video that you can add to your footage maybe with a Track Matte. If you need footage of that little band, let me know, as I've got a ton of VHS capture footage, and should be able to Crop to just that area and burn to DVD for you
Like Craig, I've not seen a kit solution. I think it will more of a list of visual clues and then choosing an Effect to get that look.
I'd get out the pad and pencil (or wordprocessor in Outline mode) and use your observations to start that list. Others will likely add to it.
After you have your list of what constitutes that look, folk here can make suggestions on how to achieve them in PP.
Hunt
Simple. Export to DV tape. Copy to VHS. Capture that through a ADVC and start editing.
Use the oldest, most mis-aligned VHS recorder you can find, preferably with dirt clogged heads, use lousy cables, record on a tape that has been used numerous times, modify the quality on export to 1.0, and you will be good. Why would you want that?
Jul 06, 2008 Jul 06, 2008
If you also have After Effects, AE has a few "video distortion" effects that might be what you want.
Jul 12, 2008 Jul 12, 2008
I found out that Final Cut has it - the filter is called Bad TV.
Get a Mac and get FCP if you have money to burn or use the solution in #3.
While there are cheaper, more creative, and effective solutions like those mentioned above, Digieffects makes a plug-in set called " Damage" that will get you the look you're after. At $99, it'll hardly break the bank, either.
Side note: why, after years of trying to get cleaner, sharper, higher-resolution video, are we suddenly enamored with video schmeg? Strange... :P
Colin,
I'd be willing to bet that this particular footage will either appear as a PiP in a TV set, or will be a lead-in to establish TV/VHS in the past. At least I *hope* that is how it's being used.
Hunt
Jul 13, 2008 Jul 13, 2008
Thanks for that link, Colin, I'll have to give that a shot.
Simulating old technology is useful at some point or another. Be it vinyl records, distorted two-way radios, or old video tapes.
Adobe Employee ,
Jun 14, 2012 Jun 14, 2012
In addition to the Damage plug-in that Colin mentioned, there's also Old TV in Video Essentials V by NewBlue, and Old TV in CoreMelt Complete V2 by CoreMelt (MacOS only), to name a few.
If you're looking for other plug-ins, take a look at the plug-ins list here - http://www.adobe.com/products/premiere/extend.displayTab4.html.
Guest
Jun 11, 2012 Jun 11, 2012
I have always wondered about such a filter as well.  The editing team for Tim & Eric from The Cartoon Network's Adult Swim know how to do it.
Apparently, it is currently a trade secret that only high profile editing teams have access to.
Convert your HD video to SD VHS just to achieve this effect?  So funny!  Once you downgrade computer media, there is no way to suitably upscale it back into HD.
The "Damage" filter and FCP solutions mentioned create the effect of old-tyme film, but not that particular VHS effect.
Try the free presets for Adobe Premiere Pro at this location: http://www.studio1productions.com/Articles/CinemaFX.htm
Scott
Contributor ,
Jun 15, 2012 Jun 15, 2012
Hi Scott,
did you get these presets to work and if so are you using CS6?
thanks
Darren
I did install them and played around with them a bit, but I have not used them in a production yet. I am using CS6.
Contributor ,
Thanks Scott,
I did try but I cant get them to load. I did follow the instructions to the T.
Darren
Sorry, I cannot remember what I did, but I either imported them with Premiere Pro open or changed the suffix of the file name and copied them into the presets folder to get it to work.
Contributor ,
Thanks Scott.
I got it working. I saved the the file as Cinema-FX.prfpset and not a XML (this is when I saved it from http://www.studio1productions.com/Articles/CinemaFX.htm) and all works well.
Darren
Nattress Big Box Of Tricks - TV Effects isnt bad.
Best way I have done this is to actually use a VHS camera in production, and then digitize from a VHS deck through my capture card..
Sorry, that is assuming you also have access to FCP  as well as PP for the Nattress TV Effects plug-ins.
Guest
Why is it that this thread is so polluted with people trying to make suggestions that are totally off the mark?  Why is it so hard to understand what is wanted when someone requests a "VHS-look-alike filter?"
And isn't it implicitly understood that a person has to have access to something in order to use it?
So much confusion over something so simple.  Must be something in the water supply.
The original poster mentioned FCP, so I assumeed they had access to it. Maybe they don't?
I think it is "implicitly understood " that people who inquire about a plug-in may actually have money to spend to purchase the plug-in they are looking for.
If you have  always wondered about such a filter then I would guess that you have done some research in this regard.
Care to share any of that info ?
Advisor ,
Boris Continuum (BCC7 or 8), which will work in Pr, has a bad video effect.  Can't remember the name, but it has lots of controls.  BCC7 is a comprehensive, useful and somewhat expensive suite for Ae and Pr.
I believe that the aforementioned Damage also works in Pr.
And yes, there are some obstinate geezers on this list with ridiculously high post counts who think they have to pipe in on every thread to add unhelpful information.  That's a price of a free and open internet, I guess.
There is BCC Damaged TV + a bunch of others like BCC Scanline that can accentuate the effect in BCC8.
Guest
"Money is not about what you earn, but rather what you negotiate."
I've bought plenty of software in my lifetime, have you?  It is my preferred method of voting for favorites in the marketplace.  Why would anyone be making conjectures as to how much money anyone "has access to" on this forum?  They could be mistaken!
