Hello All,
Periodically, when inserting and saving images into a X5
project, the application appears to be adding a path.
Correct image path should be: img src = "NameOfImage.gif"
What sometime occurs is: img src ="../NameOfImage.gif"
Removing the ../ causes the image not to appear in the
WYSIWYG Editor.
The ../ is particularly annoying when impletmenting Peter
Grainge's Show All or Twisties procedures, as I get an Object not
found message.
The only why to correct the issue, that I am aware of is to
create a New Topic, add the text and create a new drop-down, add
corresponding code and add the Script file.
Any suggestions what is causing this periodic behaviour?
