Show 6 replies
1. Re: PPCS3 won't export only the work area to media encoder
Eddie Lotter Apr 2, 2009 5:38 AM (in response to Tayedrummer)Are you sure you're not confusing the sequence In and Out Points with the Work Area Bar? I've seen people make that mistake before. The Work Area Bar is what controls the "Work Area" export.
If it's not that then you have a real mystery on your hands. :o
Cheers
Eddie
PremiereProPedia ( RSS feed)
- Over 350 frequently answered questions
- Over 300 free tutorials
- Maintained by editors like youForum FAQ -
2. Re: PPCS3 won't export only the work area to media encoder
Tayedrummer Apr 2, 2009 11:36 AM (in response to Tayedrummer)Thanks for the reply Eddie,
I'm using the bar that is underneath the timecode ruler (see http://i205.photobucket.com/albums/bb193/Tayedrummer_photo/PremiereDesktop.jpg )
I am still able to export the work area to Encore successfully but no luck to the media encoder.
Any thoughts? -
3. Re: PPCS3 won't export only the work area to media encoder
Eddie Lotter Apr 2, 2009 1:35 PM (in response to Tayedrummer)>the RANGE option in EXPORT SETTINGS the media encoder still shows only the entire sequence.If you click in that field (to give it focus) can you then use the up or down arrow key on your keyboard to change the option?
Cheers
Eddie
4. Re: PPCS3 won't export only the work area to media encoder
Tayedrummer Apr 2, 2009 2:08 PM (in response to Tayedrummer)Yup, as you can see here: http://i205.photobucket.com/albums/bb193/Tayedrummer_photo/PremiereDesktop1.jpg
I have a :30 long clip in the work area but when I go to the media encoder you can see I have WORK AREA already selected (I've tried switching back and forth without any success) yet the preview window is showing previewing a portion of the sequence I didn't want to export and is showing that the final output will be 12:17.
Back at you guys, -
5. Re: PPCS3 won't export only the work area to media encoder
Bill Hunt Apr 2, 2009 6:10 PM (in response to Tayedrummer)Tayedrummer,
One of the few "glitches," that I encountered with PrP2 was similar to what you are getting. Regardless of what I checked, and how I set the WAB (for some Projects), I could ONLY get the full Sequence. Never found out why my checking WAB Export was ignored, but on occasion, it would be, and I could never get it to take.
Wonder if you experience with CS3 is just what I got with PrP2? Most of the time it would work, as designed and intended, but sometimes it would not. Do not know what the differences were, because everything that I checked was exactly the same, in Projects that worked 100% as with the ones that failed to accept the WAB.
Good luck, and let us know what you find. Sorry that all I can do is "I've had the same/similar problem," and no workaround, or help.
Hunt -
6. Re: PPCS3 won't export only the work area to media encoder
Eddie Lotter Apr 2, 2009 7:23 PM (in response to Tayedrummer)Just for laughs, go to Marker > Clear Sequence Marker and clear the In and Out points. Then try to export the WAB again.
Cheers
Eddie
