Using CFquery to insert
Feb 09, 2007 Feb 09, 2007
Hello,
I am using CFquery to insert data from a form into an Access database. If all fields are not entered a message is returned indicating that "Element X is undefined in FORM." The Access database fields allow null values. If I entered data into every field it works fine. I have tried using cfqueryparam to check for null but have had no luck. My code is below. Any help is greatly appreciated.
INSERT INTO ISDSUserSurvey
(1)
VALUES <cfqueryparam value="#trim(form.1)#" cfsqltype="CF_SQL_VARCHAR" null="#YesNoFormat(not(len(trim(form.1))))#"/>
and this code:
(1)
VALUES (<cfif IsDefined("#Form.1#") AND "#Form.1#" NEQ "">
'#Form.1#',
<cfelse>
NULL,
</cfif>
Advanced techniques
338
On your form, what type of element is form1?
Hello, the input type is radio button with three options.
If nothing is selected, your variable won't be defined. That's why your cfqueryparam didn't work. Your approach only works when the input is a text box or drop down,
Your 2nd attempt failed because "#Form.1#" is a string, it is not outputting a variable. The simplest thing is to get rid of it.
Great thanks!
Do you have a method that will work for radio buttons, check boxes, and text fields?
the cfparam tag may be helpful. details are in the cfml reference manual. If you don't have one, the internet does.
Documentation
