Show 6 replies
1. Re: Premiere Pro v4.01 Problem with Mercalli
(tlc51369) Nov 23, 2008 8:48 AM (in response to juskocf)>Prodad Mercalli works normally in PPro v4.00
How did you get it to work with 4.0? I couldn't do it and contacted Prodad. They said they are working on it. -
2. Re: Premiere Pro v4.01 Problem with Mercalli
juskocf Nov 24, 2008 4:37 AM (in response to juskocf)I don't know but it worked in 4.00. My OS is vista ultimate x64. But now in 4.01, nothing happens when mercalli is dragged into the footage. -
3. Re: Premiere Pro v4.01 Problem with Mercalli
(a380) Nov 27, 2008 5:58 AM (in response to juskocf)There are a new update available:
http://www.prodad.de/gb/support.html#Service -
4. Re: Premiere Pro v4.01 Problem with Mercalli
(tlc51369) Nov 27, 2008 10:04 AM (in response to juskocf)The update sure has it's limitations!! If your clip is trimmed it will not work right! -
5. Re: Premiere Pro v4.01 Problem with Mercalli
juskocf Nov 27, 2008 5:29 PM (in response to juskocf)Thanks a380 and tlc51369. Updated and is OK now. -
6. Re: Premiere Pro v4.01 Problem with Mercalli
(tlc51369) Dec 10, 2008 9:04 AM (in response to juskocf)Here is a tip for Mercalli users...
If you nest the clip you are trying to stabilize first, Mercalli will render the whole clip the way it should.
