Show 5 replies
1. Re: No transitions after rendering
Jeff Bellune Dec 28, 2008 6:30 AM (in response to (Kees_Jansen))Add an Opacity keyframe to either of the clips involved in the transition.
You don't have to change its value; just leave it at 100%. It also doesn't matter what frame you use to set the keyframe.
This should be a sticky or a FAQ entry.
I'm going to try to update the Wiki. -
2. Re: No transitions after rendering
(Kees_Jansen) Dec 28, 2008 6:54 AM (in response to (Kees_Jansen))Thanks Jeff,
I tried it and it works !
Is this a bug or a "new feature" ?
>Add an Opacity keyframe to either of the clips involved in the >transition.
>You don't have to change its value; just leave it at 100%. It also >doesn't matter what frame you use to set the keyframe.
>This should be a sticky or a FAQ entry. -
3. Re: No transitions after rendering
Jeff Bellune Dec 28, 2008 7:08 AM (in response to (Kees_Jansen))It's a bug. Older versions of Pr had a default opacity keyframe set automatically, which is counter-intuitive to most motion graphics artists and video editors who have experience with animation. Typically, editors won't want *any* animation keyframes set unless they do it themselves. Just look at After Effects.
CS4 doesn't have the default keyframe, and I suspect that is the source of this issue.
EDIT: I added a new FAQ article to the Wiki. -
4. Re: No transitions after rendering
Ann Bens Dec 28, 2008 7:34 AM (in response to (Kees_Jansen))I am not a motion graphics artist but this way is much beter, being able to set your own keyframe instead of Premiere doing it for you. I was always busy removing them.
But now that the new 'old' way messes up the transitions is indead a bug. -
5. Re: No transitions after rendering
Eddie Lotter Dec 28, 2008 8:25 AM (in response to (Kees_Jansen))Thanks to Jeff: FAQ:Why do my transitions stop working after I render?
Cheers
Eddie
PremiereProPedia ( RSS feed)
- Over 300 frequently answered questions
- Over 250 free tutorials
- Maintained by editors like youForum FAQ
