5 Replies Latest reply on Jan 29, 2009 4:55 PM by Jeff Bellune
    Crossfade Transition not Working with Titles
    Pete Vojtik Level 1
      When applying a cross fade transition to two titles that were created in Premiere CS4, the transition works fine until it is pre-rendered or rendered with Adobe Media Encoder. Also, the transition only seems to fail when it is applied to either end of a title. A transition between video clips or other graphic assets appear to work fine.
      I contacted Adobe Support and they indicated that this was a known issue and that a future patch would fix the problem. I've already worked around the issue, but I thought I'd ask around to see who else knows about this. I didn't find any material on it in the Forums or web. Is there a place to find out what fixes are going into CS4 patches?
