I am trying to delete an empty folder from Robohelp. I've had
this problem before & resolved it following some advice from
this forum. The problem this time seems to be a file called
ehlpdhtm.js (found in the Baggage folder). The instructions I got
before said to remove all references to this file. The problem is:
this file is in the code for every single topic I have. So I don't
know what to do to fix it. I have 13,000 topics in my help file so
there's no way I can remove it from all of them. Any suggestions?
thanks!
C
The ehlpdhtm.js file is added to each topic regardless of
whether the topic actually needs it. It contains dynamic HTML code
(e.g. drop down or expanding text). If your topics do not contain
any dynamic HTML then it is probably safe to remove the file from
baggage. If you can't do this from within RH, open the rhbag.apj
file in Notepad and remove it there. I recommend the usual advice
about taking backups before doing anything though.
yippee!! the folder is gone. Thank you so much, Colum. I had
read an old message that talked about editing that file in notepad
but they weren't specific enough. Also, I didn't realize it
wouldn't hurt my entire file. It's gone. Thanks again!
