Could not generate stub objects for web service invocation.
Jan 29, 2007 Jan 29, 2007
Trying to consume a .NET web service, this code throws an error:
---------------------------CODE--------------------------------------
<...standard HTML deleted for brevity>
<cfinvoke webservice=" http://www.xmlme.com/WSDailyNet.asmx?WSDL" method="getDotnetDailyFact" returnvariable="aString">
<cfoutput>
Daily DotNet for #DateFormat(now(), "MM/DD/YYYY")# is <br>
#aString#<br>
</cfoutput>
----------------------ERRROR------------------------------------
Name: http://www.xmlme.com/WSDailyNet.asmx?WSDL. WSDL: http://www.xmlme.com/WSDailyNet.asmx?WSDL. org.xml.sax.SAXException: Fatal Error: URI=null Line=9: The element type "p" must be terminated by the matching end-tag "
Has anyone encountered this before? We run IIS6 with CFMX 7.02 on JRun4 Updater 6 in distributed mode.
Advanced techniques
909
I just ran your example code and I received the following result. If
this is not the expected result, I would read this as a programming
error in the ASP web service code
<cfoutput>#aString#</cfoutput>
"The MyBase keyword in VB.NET can be used to call base class properties
or methods from a derived class that has overridden these properties or
methods."
This worked fine for me as is on CFMX 7.02 on linux. I got:
Daily DotNet for 01/29/2007 is
The MyBase keyword in VB.NET can be used to call base class properties or methods from a derived class that has overridden these properties or methods.
Mike
Thanks, Mike, for testing it.
A couple of additional questions might help our suspicion of the root issue:
(1) Are you running ColdFusion in distributed mode, i.e. web server is on a separate physical server from the JRun-CFMX server?
(2) Is your test installation outside of your firewall and using NAT?
Scott
Correction to my previous post:
(2) Is your test installation outside your firewall, or if behind a firewall, is it using NAT?
Scott
1)No, I tested this where cf, jrun and apache are on the same server.
2)Behind a firewall using a nat
Thanks, Mike. We tracked down the problem: firewall required that the developer use proxy settings and now the web service is accessible and the response is making it back via the proxy.
Scott
Documentation
