AF CS3: How do i split a video into 2???
Feb 16, 2008 Feb 16, 2008
Hey there
How do i split a video in adobe affter effects into 2 video clips??????
I can do it windows movie maker but not in after effects??
Please help
Ricky
How to
61.9K
Adobe Employee , Aug 04, 2020 Aug 04, 2020
Hi! I've noticed a lot of folks returning to this page for this info. Here's what we have available for splitting your video in After Effects.
Hope it helps!
Caroline
Enthusiast ,
Select your clip in the timeline, put the CTI where you want the split to occur and then use the CTRL+SHIFT+D shortcut to split into two layers.
Windows Movie Maker is a video editor (for consumers), After Effects is a composition/animation/effects tool (for professionals). There's quite a difference in the way each one works.
Hope this helps!
Aug 10, 2012 Aug 10, 2012
Here we are in 2012 and I have the same problem, but my Mac AE has no Control-Shift-D shortcut and I see no command to split a clip in two from the CTI. My goal is to use the first 10 and last 10 seconds of a 30 second clip but skip the middle.
Nevermind, I see now. I have "Split Layer" under Edit when the CTI is located in a composition layer.
Aug 13, 2012 Aug 13, 2012
And it's command-shift-d on a Mac.
Also, this kind of task is much more suited to a video editing program, if you plan to do a lot of it.
Oct 08, 2020 Oct 08, 2020
My ctrl+shift+D isnt working because I have an app called Ding talk and when I try to click ctrl+shift+D
only that app apperas instead of clips being splitted.PLEASE HELP:(
Thanks for that!!! it works!
Just another question though... after the split and after deleting the last part of the clip that i splited, is there anyway of removing that lightish green that it leaves behind after the split
as that lightish green bar thing under the clip makes it keep playing
Contributor ,
Feb 17, 2008 Feb 17, 2008
Not exactly sure what you're trying to do... Do you want to trim your clips outpoint? Move the CTI (current time indicator) to 1 frame before where you want the clip to end. alt ]
If you want to trim inpoint, alt [
Do you want to trim your comp length to the length of both of your clips? Select both clips, ctrl-alt-b to set the work area to the length of your clips, and then composition/trim to work area (or whatever it's called).
Not sure what you mean. The ghosted/ dulled areas of the clips always represent its original soiurce duration even after parts of them have been removed. They should however not have any influence on the actual rendering and not show up. Are you sure you are working in the composition, not the layer viewer?
Mylenium
Adobe Employee ,
Hope it helps!
Caroline
