Show 3 replies
1. Re: Need expression to produce strobe effect or step frame effect
Mylenium Jul 22, 2008 9:42 PM (in response to (Nic_Coe))Effect --> Time --> Posterize Time should sufficiently take care of stuttery time remapping. You may just need to pre-compose. Other than that there is a similar method for expressions:
//===begin expression===
posterizeTime(5); //5fps
[value[0],value[1]]
//===end expression===
Mylenium -
2. Re: Need expression to produce strobe effect or step frame effect
(Nic_Coe) Jul 22, 2008 10:10 PM (in response to (Nic_Coe))Thanks Mylenium,
They work a treat ....
Nic -
3. Re: Need expression to produce strobe effect or step frame effect
David Wigforss-Hv1BNN Jul 23, 2008 9:18 AM (in response to (Nic_Coe))Another way, with your beginning and end keyframes in place: The Wiggler!
Frequency = fps/step (ie 29.97/5).
Magnitude = 0.
Then select all the keys and change to hold.
