Show 8 replies
1. Re: Burning to Disc vs Buring to ISO file ? ? Why ?
John T Smith Sep 6, 2007 6:09 PM (in response to (Video123))I think "most" suggest that only as an answer when someone asks "why can't I burn a DVD"
The advantage of an .ISO is that you may then burn as many copies as you want
If you only ever want one, and you don't have any of the problems people ask about, going directly to DVD may be best for you -
2. Re: Burning to Disc vs Buring to ISO file ? ? Why ?
(Video123) Sep 7, 2007 10:17 PM (in response to (Video123))Thanks for the info - Video -
3. Re: Burning to Disc vs Buring to ISO file ? ? Why ?
(C._David_Young) Jan 17, 2008 8:41 PM (in response to (Video123))A lot of people have problems going directly to DVD from Encore. The workaround is to create the .ISO and use other software like Nero for burning it. -
4. Re: Burning to Disc vs Buring to ISO file ? ? Why ?
(Patrick_Graham) Jan 27, 2008 7:22 PM (in response to (Video123))I have the new CS3 and created a video in Premire Pro and then exported it to Encore where I continue to get this message. I have to export it to Elemenets 3.0 to be able to be successful Any hints on how to use Encore Correctly and avoid this message? Thanks Patrick
PGC "DVD1" has an error at 00;33;59;29.
internal software error:%0,line DVD1-PGC info: name=DVD1,ref=Kpgc,time=00:33:59:29 -
5. Re: Burning to Disc vs Buring to ISO file ? ? Why ?
John T Smith Jan 27, 2008 8:13 PM (in response to (Video123))Start with the FAQ http://www.adobeforums.com/webx/.3bbe249a/
Look for the article about things and software to avoid -
6. Re: Burning to Disc vs Buring to ISO file ? ? Why ?
(FeFe3d) Nov 10, 2008 5:08 AM (in response to (Video123))I have a problem to burn a dvd.
I`ve check the proyect and works correctly.
I build a dvd folder in may hard disk and encore cs3 create some folders.
I,ve burn a dvd with this folder in nero, but when I want to play it does not work.
which are the archive I have to burn and how ?
Thanks. -
7. Re: Burning to Disc vs Buring to ISO file ? ? Why ?
Ruud Blauw Nov 10, 2008 7:22 AM (in response to (Video123))Instead of Nero I would suggest to try ImgBurn .
Also see: Burning DVD Video files directly to single layer media with ImgBurn . -
8. Re: Burning to Disc vs Buring to ISO file ? ? Why ?
(minu_sharma) Nov 19, 2008 3:59 AM (in response to (Video123))Patrick ,
PGC error like this can come when there are HD and SD assets are put in same timeline in the project.
Please try putting SD and HD assets in different timeline. Hopefully it will solve the issue.
Minu
