Hi Vittal,
A lot depends on how your developer is calling the help file,
but it seems like your new help file just isn't connected to that
menu item. Do the other calls work OK? Any other menu items, F1
help, etc? What I would do is to use RH's BugHunter or Help
Workshop to check the message from the application. It should
return something like HH_HELP_CONTEXT and a map number or
HH_DISPLAY_TOPIC and a file name.
Make sure the map number is linked to your topic. In the
project.hh file (open it with notepad), there should be a
line #define IDNAME mapnumber. Then search for that IDNAME in your
project.ali file. It should be linked to your topic filename
IDNAME=
Topicfilename.htm. That "Topicfilename" should have no
spaces (for example, "Whats New.htm" wouldn't work).
John
