Show 2 replies
1. Re: Trouble duplicating DVD after it was created in Encore
Neil Wilkes Nov 18, 2008 3:01 AM (in response to (Bruce_Barr))Bruce.
I'm not even sure how you managed to burn a disc with any copy protection options selected in the first place!! This is normally not possible as a disc needs to be replicated (pressed) before copy protection can be added.
I think you will be better off going back into Encore, turning off the copy protection options altogether, and creating a disc image instead of burning a disc - this should allow you to make as many copies as you like with Roxio afterwards. -
2. Re: Trouble duplicating DVD after it was created in Encore
Ruud Blauw Nov 18, 2008 3:03 AM (in response to (Bruce_Barr))Instead of Roxio I would suggest to try ImgBurn (freeware/donationware).
With ImgBurn copying is a two step process. First you create a disc image file from the original DVD. ( How to create an image file from a disc with ImgBurn ) Then you burn as many DVDs as you want from this file. ( How to write an image file to a disc with ImgBurn )
