Show 3 replies
1. Re: End of file
Bill Hunt Nov 30, 2008 1:26 PM (in response to (rik_vd_Wildenberg))Unfortunately, Check Project only does a check on the general navigational structure. It is not like a "pre-flight" check in a publishing program like InDesign. Unfortunately, there can still be problems with Assets. Often, Preview will not show these up, as it is just an emulation.
The first thing that I would carefully check is that you have no Timeline(s), where the Audio is longer than the Video, even my a very tiny amount. Zooming the Timeline display can often allow you to spot these. A close check of the Duration of your Assets in the Project Panel can also verify this.
If this visual check doesn't find any problems, you might give more details on your Project and your Assets. More details are better than too few.
Good luck,
Hunt -
2. Re: End of file
(rik_vd_Wildenberg) Dec 7, 2008 7:56 AM (in response to (rik_vd_Wildenberg))My audio file is indeed 1 or sometimes 2 frames longer as the video file.
I have set the audio out-point earlear than the video out-point.
Then it is working fine!! Thanks a lot for your input. -
3. Re: End of file
Bill Hunt Dec 7, 2008 7:18 PM (in response to (rik_vd_Wildenberg))Rik,
I'm glad that it is working for you.
So far, I've only done Export as DV-AVI (Video only) and AC3 (Audio only) in elemental streams. To date, the Duration of each has been 100%.
Hunt
