3 Replies Latest reply: Apr 3, 2006 11:20 AM by Averdahl RSS
    How to customize shortcuts in Encore DVD 2.0?
    Averdahl Community Member
      Hi!
      I need to customize some shortcuts because i am using a keyboard with a Swedish layout. If i press Ctrl+; to show guides on a menu the menu zooms out...
      In "C:\Program Files\Adobe\Adobe Encore DVD 2.0\Required" there is a file named keymap.xml that i have customized some shortcuts in, but not all of the aviable shortcuts, Ctrl+; included, can be found in that file.
      So, do you know where i can find the file so i can change Ctrl+; to something else? Is it possible at all?
      /Roger
        • 1. Re: How to customize shortcuts in Encore DVD 2.0?
          I still need help on this one and would be very greatful if anybody has an answer! :)
          /Roger
          • 2. Re: How to customize shortcuts in Encore DVD 2.0?
            Community Member
            There's no supported mechanism for modifying shortcuts in 2.0, sorry. It is on our list of feature requests though...
            It sounds like "Ctrl + ;" is mapped to "Ctrl + ," on your keyboard. The Swedish keyboard layout shown in the link below shows that the comma and semi-colon characters share the same key:
            http://www-306.ibm.com/software/globalization/topics/keyboards/KBD285.jsp
            Try holding the Shift key down when you use "Ctrl + ;" to see if that gets you the Show Guides gesture.
            -Larry
            Encore DVD QE
            • 3. Re: How to customize shortcuts in Encore DVD 2.0?
              Larry, thanks for answering!
              You are right, i can only get Ctrl+, on a Swedish keyboard. The stange thing is that Ctrl+, showed guides in Encore DVD 1.x. For some reason it does not work in Encore DVD 2.0.
              I tried Shift and Ctrl different keys in different combinations to no avail. I can not use any shortcut that involves semicolon.
              I did send in a bug report for this and a feature request for customization of keyboard shortcuts today.
              /Roger
