4 Replies Latest reply: Apr 6, 2009 10:56 AM by Bill Hunt RSS
    Sound in motion menu
    Bingo888 Community Member
      Hi All,
      I have motion menu with sound with endless loop.
      in the first loop it plays well and from the second loop and
      on the sound starts in delay. Does anyone have an idea for the reason
      and how to solve it?
      Shaul
        • 1. Re: Sound in motion menu
          Neil Wilkes CommunityMVP
          Is this in preview or on a real disc please?
          If in preview, what happens if you actually write to a disc?
          (An RW would be the best option here)
          • 2. Re: Sound in motion menu
            Bill Hunt CommunityMVP
            Also, check that you do not have any Loop Points set.
            As Neil points out, Preview/Emulation is just an *approximation* of what the DVD will be like. It is OK for minor checks, but doesn't get everything right.
            Good luck,
            Hunt
            • 3. Re: Sound in motion menu
              panos pan
              Hi all.I have also a lot of problems in motions preview(the video that i use for motion menu does not freeze in the last frame ,and i can see black or red for 2 sec before it loops back again, the preview is very bad and if you try to press a button it freeze and the audio starts from zero point again ,i dont have video export thru 1394,).IF i burn it to disk everythig works perfect but how can you bild a project ..with no preview!!!!I updated from encore 2 in cs4 and takes more time to do the same job.. I use new Pc in 64 bit vista with 12g ram ,1g ati 4800,p6t and i7 920 cpu.
              • 4. Re: Sound in motion menu
                This is a known issue with the use of Preview. One needs to Burn to Folder, as you are doing, or Burn a DVD RW to test. It's one of the things that one gets used to. Do not know what the exact cause of this is n Preview, but it's been around long enough, that if it were an easy fix, Adobe would have nailed it by now. Do not know if it happened back in Encore 1 (wasn't that the last ver. to use DirectShow?), but from Encore2, it's been there. Nature of the "beast."
                Good luck,
                Hunt
